Visits: 3.6K
Ok, stupid question....how many threads on the adjuster should be showing out of the bottom of the rocker on Initial set-up to check pushrod length? I have 8.125" tubular push rods that came out of the engine when it had C1TE heads and low ratio rockers. In that case there were 6 threads showing. With the same pushrods, ECZ-G's and ECG-6564 rockers, I get the same 5-6. I figure with the 8.320" pushrods I'll have around 3 threads. That seems better to me because that's how my T&D's are set on my big block Chrysler. Different animals, but just want to be sure. Thanks for your time!
Posts: 7.5K,
Visits: 205.8K
When in doubt, just target for an equal number of exposed adjuster threads at both the top and bottom of the rocker with the valve lash also taken into consideration.
Visits: 3.6K
Thank you Sir!
