Last Active: 8 Months Ago
Visits: 14.6K
I want to change to an electric choke on my 56 Fairlane with B manifold and Autolite 4100. The heat controlled choke works ok. There seems to be an exhaust leak somewhere in the either the heat tube, mushroom cap or the plumbing from the manifold to the carb. I've never been able to find the right fitting that goes from the manifold to the choke. It may be leaking there. I can't find the leak when it's idling or reving it up but I can sure hear it while driving. I've about given up on trying to keep it looking original and rather just have reliable functionality. No one seems to list the cap origin other than "imported". I'll be damned if I will ever use chinese parts, especially something electric near a fuel source.
PS can someone please fix the title? Something went wrong typing. "Recommendation for good non-chinese electric choke caps for Autolite..."
~DJ~ AKA "Bleach" 1956 Ford Fairlane Town Sedan 30K original miles
Visits: 13.5K
Ford never made one, I don't remember if the aftermarket ever did, however you may check a Edelbrock AFB it may fit.
Posts: 7.5K,
Visits: 205.8K
Visits: 14.6K
Thanks for the tips, I''ll check those out. Also thanks for fixing the title.
Last Active: 3 Weeks Ago
Visits: 32.6K
56_Fairlane (6/6/2020)
I want to change to an electric choke on my 56 Fairlane with B manifold and Autolite 4100. The heat controlled choke works ok. There seems to be an exhaust leak somewhere in the either the heat tube, mushroom cap or the plumbing from the manifold to the carb. I've never been able to find the right fitting that goes from the manifold to the choke. It may be leaking there. I can't find the leak when it's idling or reving it up but I can sure hear it while driving. I've about given up on trying to keep it looking original and rather just have reliable functionality. No one seems to list the cap origin other than "imported". I'll be damned if I will ever use chinese parts, especially something electric near a fuel source. PS can someone please fix the title? Something went wrong typing. "Recommendation for good non-chinese electric choke caps for Autolite..." If You can hear an Exhaust Leak when driving I suspect its not the Choke Setup. I had to resurface both Exhaust Manifold flanges to fix an Exhaust Leak on mine.
Visits: 14.6K
One more thing, what works best to plug the heat holes in the manifold?
Visits: 32.6K
One more thing, what works best to plug the heat holes in the manifold? I tapped the Holes and used I think 5/16 or 3/8 Bolts.
Posts: 3.3K,
Visits: 238.8K
Don't know if this info will help but.. the exhaust leak may be the choke heat tube inside the crossover being corroded out, a fairly common problem with old 'B" intakes. I believe some of the T. Bird parts suppliers have that replacement heat tube. They may also have the heat tube to carb connection setup. The only hanger on that is the original tubes were coated with an Asbestus material which may not be available now?. I couldn't find a replacement tube in Canada, when I replaced mine, (a place on e Bay offered to sell me a pk'g of 4) so I made and installed a new complete setup from small copper tubing & copper fitings. For insulation up to the carb I used cotton wrapping that was soaked in Borax to make it fire resistant. So far it seems to be working & holding up o.k.. Note; My carb is also an Autolite 4100, and my exhaust doesn't have a diverter valve as two large parts outfits had no listing for them now + my intake crossover has Truck gaskets, which partly obstruct crossover heat, so I set the choke to not close fully & it seems to work fine. Obviously, I don't drive the car is dead cold of winter..
Visits: 14.6K
I had replaced the heat tube in the manifold but it still had that small exhaust leak as before. The manifold surfaces looked flat and didn't have any signs of exhaust soot when I removed it to replace the tube. I can only figure exhaust is still leaking into the choke tubing since I saw some soot in the choke housing of the carb. Either way I found a electric choke from a seller in Eugene OR for fairly cheap. I did have to flip the coil in it though since it turned in the opposite direction than my original. Now I just need to plug the heat orifices in the manifold and wire up the cap off the ignition switch with a fuse.
Visits: 14.6K
oldcarmark (6/6/2020)
If You can hear an Exhaust Leak when driving I suspect its not the Choke Setup. I had to resurface both Exhaust Manifold flanges to fix an Exhaust Leak on mine. I replaced the heated choke with the electric one and plugged the two holes and still noticed the same exhaust leak. It looks like I'll need to find someone who can resurface the manifold. If not, I may just go back to the original A manifold and rebuild the teapot. I guess I took it for granted that the manifold flanges were flat. In all my years of working on cars I've never had any manifold that had a warped flange. I've had cracked exhaust manifolds but never a warped intake. Is this common on B manifolds?
