MattsY
Visits: 3.6K
Just curious if anyone has ever seen this before. After getting my crank back from the grinder and attempting to drop it into the block...it wouldn't go in. I thought maybe he made a mistake as I was cutting a 312 crank to fit a 292 block and offset grinding the stroke to 3.500". When I brought it back he said he couldn't understand why it wouldn't drop in, so we tried it in another block he had in the back and wouldn't you know it, it dropped right in! In looking at the block he had in the shop I knew immediately the receiver groove for the oil slinger was not the same as my block, so I went home to investigate and here is what I found.....
Daniel Jessup
Posts: 2.0K,
Visits: 131.2K
what did you find? a star and a thumbs up lol? seriously - looks like a photo is missing...
MattsY
Visits: 3.6K
Sorry all! For some reason the forum will not let me post a picture. Basically, the receiver groove in my block was cut with a very prominent "step" that prevented the crank from dropping in. I had to cut down the oil slinger to get it to fit. This is a Ford Industrial engine that traces back to an Onan generator. Could this have something to do with it?
MattsY
Visits: 3.6K
The site keeps telling me "cannot load content at the moment"
MattsY
Visits: 3.6K
Fixed it! Couldn't pull images from my phone. Sorry 'bout that!
What is the casting number and date code on the block? Many of the 1954/1955 blocks were not machined to accommodate the crankshaft oil slingers. Those particular blocks do require crankshafts that do not have crankshaft oil slingers.
MattsY
Visits: 3.6K
It's a C2AE block, not sure on the date. I do knowthe crank that came out if it did in fact have the slinger, but it's diameter was about .200" smaller than the 312 crank I'm using.
The date on your C2AE block is December 11, 1963. The O.D. on the 312 crankshaft slinger is larger than that of the 292 oil slinger. When cutting down the 312 mains down to the 292 size, the O.D. of the oil slinger must also be cut down to the appropriate 292 size.
MattsY
Visits: 3.6K
Gotcha! Obviously, the grinder didn't do that. Fortunately, I have a lathe large enough and did it myself. Took it down to the diameter of the original and it fit like a glove!
blocky
Visits: 2.9K
that is very interesting . thumbs up
