Visits: 3.4K
Did you rebalance the crank, or do you think not enough taken off to make a difference?
Machining the OD of the rear oil slinger by itself will not necessitate any additional rebalancing of the crankshaft. Changing the rods and/or pistons where the weight of those is different from stock does require the crankshaft to be rebalanced.
Visits: 3.6K
No, no rebalance. Minimal material removal, but necessary material removal!
