Visits: 3.5K
Does any one know where to buy a Hurst 3 speed shift kit for a 1956 Ford Fairlane w/Overdive? Thanks in advance, Tim Hot 'n Humid , Florida 33706
Visits: 6.5K
I used a 3 speed Hurst in my 55 Tbird decades ago. Worked great. I still have it somewhere if you are interested.
Bill A wabateATverizon.net
Visits: 3.5K
Yes I'd be interested if it will bolt on to the overdrive tranny in my '56 Crown Victoria. There is a solenoid on the side of the tranny that could be a problem. (I think) Maybe someone out there will know. Thanks for your reply, Tim in Florida
Last Active: 8 days ago
Posts: 1.9K,
Visits: 195.0K
I'm not going to be much help, all my experience is with Thunderbirds, and I expect the shifter location will be different in a Fairlane. That said, here's what I remember.
I had a Hurst Syncro Lok (?) in my 55 bird many years with a T-85 o/d. The local speed shop worked with me, and it used the short stick for a Corvette. I had to modify the brackets for the shifter location in a bird. Might have been a passenger car unit, but after 50+ years I don't remember. I also had a Hurst Mystery Shifter on a T 86 o/d in a 59 bird. Both worked fine, but both had to be altered (not many 59's around with stick shifts).
There's been some discussions on other sites about shifters for the o/d units, they're a little more difficult to find apparently. The shifter on my T-5 on the bird is very near if not on the original location, and is roughly 25" from the block-bellhousing to the shifter. Somebody might be able to give you a better measurement. Either way, you'll need to know where the shifter clears the seat, and some location back to see how a bird unit clears.
They're not rocket science, any unit will work if you've got a torch handy to make the modifications, bend the arms, etc.
Visits: 14.3K
The overdrive shifter is different due to the solenoid. Finding a original one is rare and I dont think anyone is making new ones. I've been looking for one on Ebay for a couple years now.
Durham Missouri
Visits: 3.5K
Miker, Thanks for the reply. Let's see if any of the Y Blockers can come up with more info about a Hurst 3 speed shifter working on a '56 Fairlane w/overdive. Again thanks, Tim Hot 'n Humid Florida 33706
Visits: 23.2K
Just make sure you don't turn the arms over when installing the shifter rods, the shift pattern will be backwards. Made it easy to snatch second gear, though. Ask me how I know? LOL. '56 Fairlane Victoria(1962-1966) Joe-JDC
Posts: 2.0K,
Visits: 131.2K
Tim, If you have not visited my website, I encourage you to do so. There is way too much information (such as the exact shifter you are talking about here) covered in my blog posts. Here is a good place to begin: https://www.hotrodreverend.com/post/2017/09/20/55-ford-restoration-blog-part-10There are several other posts I make on the blog that specifically concern the installation, adjustments, parts, etc, etc. And, the individual I bought the brackets from (which is really the most difficult to find for the OD transmissions) can be found at this link: https://www.ebay.com/usr/4ever4dyes, that is an eBay link, but that is the medium he uses to peddle parts - a very knowledgeable guy and he was a tremendous help to me after he sold me what I needed. Here is a current listing at a very good price: https://www.ebay.com/itm/52-65-FORD-3-SPEED-OVERDRIVE-HURST-SYNCRO-LOC-SHIFTER-MOUNTING-BRACKET/264743270494?hash=item3da3edb85e:g:0eAAAOSwTf1ezECgI suggest you shoot him a message to find out what else he has in stock. Once you look over his items he has up for sale, you will come away with the idea that he knows Ford transmissions pretty well. I am very happy with how things ended up I might add.
Visits: 3.5K
Bless you Reverend, I really appreciate you taking time to supply me with this information. Tim Hot 'n Humid, Florida 33706
Visits: 14.3K
Do you have a T86 or T85? The bracket that Dan posted is for a T86 OD.
Durham Missouri
