Visits: 3.5K
I 'm trying to find out what I have. I see numbers on the tranny but none say what it is. Where should I look ? Thanks, Tim Wet 'n Soggy, FL 33706
Last Active: 8 Months Ago
Visits: 183.3K
If it has  a 'curved bottom' side cover it's a T-85
"FREE SAMPLE"
Visits: 3.5K
Dear Lord, Thanks, the tranny is a T-85 so that bracket on Ebay will not work Thanks for you time and effort, really appreciated. Tim Wet 'n Damp Florida 33706
Posts: 2.0K,
Visits: 131.2K
contact the seller with a message on eBay - he did not have what I wanted listed in his eBay store but he did have it in his stash of parts and it was very reasonable.
Posts: 2.0K,
Visits: 131.2K
There there is I found... https://www.ebay.com/itm/hurst-3-speed-shifter-T85-T86-overdrive-1949-57-Ford-Mercury-Lincoln-Thuderbird/233575353841?hash=item36622d0df1:g:HTUAAOSwk9xeq2xN:sc:USPSPriority!45140!US!-1don't know the seller but check this out at any rate...
Visits: 1.4K
I had the OD transmission and spent a long time looking for a Hurst (or any) floor shifter and never found one. Eventually went with a 5 speed mustang using a Mummert adapter. Still have to fabricate a decent shift lever and boot, otherwise a great swap. I have a long paper explaining all the details if anyone is interested. Write me directly at jackgr@aol.com.
Visits: 3.5K
On second thought, because of all the complications, I'm going to leave it stock. The O/D is working great and 'if it ain't broken, do't fix it". Leaving it stock, might make it easier to sell to a buyer who wants stock. Thanks to all the Y'blockers who contributed to me with advice and help. Tim Nearly dead or Newly wed, Florida 33706
Visits: 285.6K
Sounds like you have a T85? If so, that's a great heavy duty transmission. I have a T86 with O/D in my Tbird. I suppose you could adapt a TBird shifter to work in your car. It mounts on the floor hump. Personally, I would keep the O/D. I love mine.
