pedal stop
Posted By stuey 6 Years Ago
stuey
Posted 6 Years Ago
Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)Supercharged (859 reputation)
Last Active: 10 Months Ago
Posts: 444, Visits: 3.8K
Hi folks
    Under the accelerator pedal in my 56 F100 there is a device that I believe to be a pedal stop.
It has a sprung loaded plunger on top with about 3/8" travel.
Part number 9A858.
What's the purpose of the plunger?
There are no electrical connections.
stuey
Lord Gaga
Posted 6 Years Ago
Posts: 470, Visits: 183.3K
Does it go "Ding-Dong" when you push it?
"FREE SAMPLE"
pintoplumber
Posted 6 Years Ago
Posts: 1.0K, Visits: 164.5K
Sounds like the kick down cutout switch for overdrive.
Posted 6 Years Ago
Posts: 3.8K, Visits: 33.4K
Its called a Detent Stop. Should be adjusted so it just touches Gas Pedal when Carb is fully open. Limits the Pedal Linkage travel.
stuey
Posted 6 Years Ago
Lord Gaga (5/13/2020)
Funny Ha - Ha.
Nice to see a sense of humour in these trying times.
Actually it does not do anything which is what's so perplexing.
stuey
stuey
Posted 6 Years Ago
pintoplumber (5/13/2020)
Thanks for reply. There are no terminals for wiring connections.
stuey
stuey
Posted 6 Years Ago
oldcarmark (5/13/2020)
I think you have something.
So should it be adjusted so it touches the gas pedal (carb fully open) with the plunger fully depressed?
The truck came with a Fordo. and it may be a physical indication with something related to its operation?
Many Thanks for all replies.
Stay safe
stuey
Posted 6 Years Ago
stuey (5/14/2020)
Stay safe
stuey
These were only used on Trucks with Automatic Transmissions. I would guess the reason they were used was to prevent damage  to the kickdown linkage used only on Automatic Transmissions.
