pedal stop
http://forums.y-blocksforever.com/Topic151823.aspx
By stuey - 6 Years Ago
Hi folks
    Under the accelerator pedal in my 56 F100 there is a device that I believe to be a pedal stop.
It has a sprung loaded plunger on top with about 3/8" travel.
Part number 9A858.
What's the purpose of the plunger?
There are no electrical connections.
stuey
By Lord Gaga - 6 Years Ago
Does it go "Ding-Dong" when you push it?
By pintoplumber - 6 Years Ago
Sounds like the kick down cutout switch for overdrive.
By oldcarmark - 6 Years Ago
Its called a Detent Stop. Should be adjusted so it just touches Gas Pedal when Carb is fully open. Limits the Pedal Linkage travel.
Lord Gaga (5/13/2020)
Funny Ha - Ha.
Nice to see a sense of humour in these trying times.
Actually it does not do anything which is what's so perplexing.
stuey
pintoplumber (5/13/2020)
Thanks for reply. There are no terminals for wiring connections.
stuey
oldcarmark (5/13/2020)
I think you have something.
So should it be adjusted so it touches the gas pedal (carb fully open) with the plunger fully depressed?
The truck came with a Fordo. and it may be a physical indication with something related to its operation?
Many Thanks for all replies.
Stay safe
stuey
stuey (5/14/2020)
Stay safe
stuey
These were only used on Trucks with Automatic Transmissions. I would guess the reason they were used was to prevent damage  to the kickdown linkage used only on Automatic Transmissions.
