Visits: 6.0K
Has anyone used the Rex headers in a 56 F100. Just wondering about clearance from the firewall on the left side. It looks from measurements it will clear my steering shaft. How good is the ceramic coating? Thanks
Visits: 190.0K
i used the right single manifold on the drivers side,this makes a nice curved pipe that mines oil filter and steering .pasenger side used the tulip with centre exit
Visits: 6.0K
Thanks for your idea, i was really looking for a header setup.
The collector, right where the 4 tubes fit together will be about 4" diagonally, between tubes and the 2 1/2" flange will be considerably larger than the stock car manifolds. Since stock manifolds don't work, unless you do what meteor said, these most likely will not either, because they are larger There are lot's of options for truck headers, Reds, Sanderson, Patriot (which is rebranded by Speedway Motors, and others).
Visits: 6.0K
Thanks for the info. My second choice was the reds headers. I will check with them for some measurements. Thanks
Visits: 4.5K
Visits: 6.0K
Those headers would be a good option, but when i installed the automatic AOD transmission i needed to install side engine mounts at the middle of the engine, because the bellhousing did the rear support. So i will need something that routes over the top and down. I have seen a large front engine mount on some other engines, but the only other support i would have would be at the tail shaft of the transmission. That looks a little to unsecure for me. I thought about fender well headers but not a big fan of cutting the fender liners. Any other ideas would be great.
Posts: 1.9K,
Visits: 195.0K
If I'm understanding, you're looking for passenger car headers (to clear the side motor mounts) that clear everything else in a truck. No clutch linkage, since it's an AOD, do you still have the column shift for the auto?
I had a set of Red's tri-Y' on my bird, and currently a set of FPA's. I know those won't clear the side mounts. None of the truck headers will. So your looking for a solution not many people need.
I understand on the fenderwell's. My best guess is maybe Red's current Tbird headers. The birds are tighter at the drivers side, just as the factory cast manifold is, and the flange is right off the tubes. That gives you more leeway on running the down pipe. I'm guessing the passenger side won't be a problem, but I'm not familiar with trucks.
Take a look at the factory cast manifolds for cars or birds. If you think you can work with that, then those headers (high and short vertically) will probably work if you can deal with the down pipe. Look at Ted's exhaust test, it might or might not be worth the effort from a performance standpoint from a cast manifold.
Otherwise it's going to be a custom build. If you go that route, post back. I know who builds the SS flanges that FPA uses and he used to sell them.
FWIW, the workmanship and coating on the Red's tri-Y's was top notch. 15 or so years ago.
Visits: 6.0K
Thanks for the ideas. I am using a floor shift for the automatic. I emailed Reds asking for dimensions on the F100 header for the volare front end, even though i am using a straight front axle. I will look into the tbird headers but i did not see them on the site. Right side exhaust wont be a problem, if that works ok i still need to get around the brake booster under the floor and the inside the frame rail gas tank on the left side for the panel truck. If you have a contact for the ss flanges i would be interested. Thanks again.
