Posts: 1.9K,
Visits: 195.0K
I think (but don't know) that Stan's builds the FPA headers I've got on the bird. When I enquired about flanges FPA sent me to Stan's, and I used those for the headers on my F code roadster clone motor. Stan does a lot of hot rod stuff, including the exhaust from the Sanderson headers back on my buddy's Nomad and numerous other acquaintances. They don't show on the site, so you'll have to call and ask. They're less than 15 minutes from me, and I drive by them once a week. http://www.stans-headers.com/headers.htm
panel driver
Visits: 6.0K
Thanks for the information. I will definitely get in touch with them, looks promising.
Posts: 3.3K,
Visits: 238.8K
What about Truck Rams Horn's, would that work for your setup? Ted our moderator, tested them some time ago, & found them to be quite effecient. And a likely a lot less noisey...
panel driver
Visits: 6.0K
I think they exhaust in the center of the engine. Anything at the center of the block on the sides won't work. Thanks for the idea.
panel driver
Visits: 6.0K
I have been thinking about using the red's dual tube headers for either a passenger car or a t bird. I was wondering if anyone has either one of these on their cars. I was hoping i could get some pictures with measurements to see if i can fit these on the truck. I spoke to victor at red's headers and said he did not have a set in stock to measure. I can't use the standard truck headers, unless i remake and reposition the side engine mounts, because of the AOD automatic setup. Thanks.
Posts: 3.3K,
Visits: 238.8K
Panel Driver: In Teds tests of exhaust setups, the Reds 2 Tube Headers, compared to regular 1957 exhaust manifolds, were a waste of time & money installing .The only thing they ad is noise & heat.. In fact the '57 exhaust manifolds were slightly better performers..
panel driver
Visits: 6.0K
I may have described them incorrectly. I was thinking about the Red's 4 tube headers for 55/56 cars. But i would be open to the 57 dual exhaust manifolds, if someone would have a set for sale and they would have a chance of fitting.
ian57tbird
Visits: 21.7K
Repo manifolds can be bought new from TBird suppliers.
panel driver
Visits: 6.0K
I was looking at the ones from Casco, are they the same measurements as the original 57 manifolds? Do you know how good the quality is? I need to call them but i have been sidetracked lately. Just wondering if you have purchased from them in the past. Thanks
Posts: 1.9K,
Visits: 195.0K
Casco is a well respected supplier to the restoration market. Everything I've had from them has been fine. But the driver side manifold is different for the bird, and that's reflected in the pricing. A good used set off a passenger car would probably work and be more reasonable price wise. Just watch for broken ears from over tightening and using gaskets.
