Mallory distributor
Posted By SVMSR1044 5 Years Ago
SVMSR1044
Posted 5 Years Ago
Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)
Posts: 7, Visits: 9.8K
Anyone have any experience with a Mallory 2538701, dual point, centrifugal advance distributor on a stock, Fordomatic 292 or 312 Y-block? Good? Bad?
Thanks, Steve
Posted 5 Years Ago
Last Active: 7 hours ago
Posts: 3.6K, Visits: 497.6K
Not on a Y and don't know if the same model, but I had a similar dizzy on a 53 merc flathead and it ran great.  It was the newer style, not the one with a two piece cap.
Posted 5 Years Ago
Last Active: 6 hours ago
Posts: 4.6K, Visits: 38.1K
The Mallory dual points worked quite well back in the day. Much better than the stock Ford. Today the electronic distributors are much better for performance. The Mallory will work fine and give you some improvement along with the "look".
Posted 5 Years Ago
Posts: 1.7K, Visits: 340.0K
I ran a 50’s distributor with a Mallory dual point plate, external brass condenser, and coil for many years. It did not have a vacuum advance. When I sold the car I took it off. It was foolproof and I never had a failure with it. Since it is a point system I did use a ballast resistor.
Vic Correnti
Posted 5 Years Ago
Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)Supercharged (707 reputation)
Posts: 347, Visits: 12.2K
Steve,
I have a dual point mallory #ZC325B tach drive distributor I ran on and off for 30 years on my Tbird. I used it in both a 292 and 312 stock and modified. It was always a great distributor and never had problems, the points stayed set. Eventually I upgraded to a MSD as I got hooked on nitrous.
Vic Correnti
Posted 5 Years Ago
Steve,
Here is a link to some information on the Mallory dual point distributor.
http://mgaguru.com/mgtech/ignition/ig200.htm
Posted 5 Years Ago
Posts: 1.2K, Visits: 285.6K
I assume you can no longer buy these distributors new?  I have heard parts are hard to find and expensive.  Is this true?
Vic Correnti
Posted 5 Years Ago
Phil,
I haven't used the Mallory for the last 10 years but I was able to always find what I needed. A quick look on the internet I see parts. As I recall points last for a long time.
Now parts for this Tach Drive Spalding might be a little harder to find. But it looks impressive on a Tbird spinning that original tach. I can remember rotating the cam to set the timing because of limited space with the Edelbrock 255 to rotate it and have the tach cable where I wanted it.
Posted 5 Years Ago
I have several of the Spalding/Grant flame throwers. Very impressive for looks but costs about 20hp to run compared to a modern electronic. Parts are nearly impossible to find. I've been looking for the side plates and internal rotors for several years. Every place I find is closed down. I've heard rumors of some parts available in Cali. but no luck so far. I have a couple of scrub types and a Hemi. The neatest thing is the wires go to the sides and are separated on the distributor right and left side. Looks a lot like a mag to many people.
Cliff
Posted 5 Years Ago
Posts: 876, Visits: 13.4K
I run a Spalding Flame Thrower in my bird for over 25 years, parts are hard to get.
