E Code Valley Pan work - had to weld it up!
Posted By Daniel Jessup 6 Years Ago
Daniel Jessup
Idea Posted 6 Years Ago
Posts: 2.0K, Visits: 131.2K
https://vimeo.com/401130048
Daniel Jessup
Red Lion, Pennsylvania
Lord Gaga
Posted 6 Years Ago
Last Active: 10 Months Ago
Posts: 470, Visits: 183.3K
Why didn't you braze it? Easier/Better!
"FREE SAMPLE"
Daniel Jessup
Posted 6 Years Ago
Lord Gaga (3/27/2020)
Never have brazed anything, not that I don't think I could handle it. I didn't have any brazing stock, and I only have a propane torch - not that you can't braze with a propane torch but the OA I'm sure would be much better. Work with what you got I suppose.
Daniel Jessup
suede57ford
Posted 6 Years Ago
Posts: 216, Visits: 106.5K
I brazed a couple I had.  It came out nice as the brass really flowed and sealed it up as well.  I honestly have not done much brass soldering, but the trick to soldering is that the solder(brass) goes to the heat.  So heat the area you want the solder to go and it flows into those spots.
Pat Fleischman
Daniel Jessup
Posted 6 Years Ago
I reckon I will have to try that route sometime. At any rate, this oil fill tube will not be coming off this pan anytime soon! w00t
Daniel Jessup
Daniel Jessup
Posted 6 Years Ago
Here is the video of the overall fit...
Daniel Jessup
