High lift Rockers
Posted By 55 GLASS TOP 5 Years Ago
55 GLASS TOP
Posted 5 Years Ago
Posts: 389, Visits: 31.8K
Hello there is a set of high lift rockers on eBay I have completely rebuilt my engine except for the rockers that were badly worn. My engine 1956 292 can I use the high lift assembly . Thanks
Joe-JDC
Posted 5 Years Ago
Last Active: 5 hours ago
Posts: 772, Visits: 22.5K
Should be good to ~.530" or so without doing a clay test.  Multiply your camshaft lobe lift times the rocker ratio that is for sale, and see if it is less than .530".  If so, good to go.  Joe-JDC
55 GLASS TOP
Posted 5 Years Ago
I am using a standard cam,  the eBay listing says  1.54 I do not know what it means. The seller says they came on all the 292 engines . But I wanted to ask here first. Thanks
55 GLASS TOP
Posted 5 Years Ago
What’s a clay test thanks
Cliff
Posted 5 Years Ago
Posts: 878, Visits: 13.5K
Check out these
https://www.ebay.com/itm/264680427545
panel driver
Posted 5 Years Ago
Last Active: 4 days ago
Posts: 119, Visits: 6.0K
Some the ones in the boxes look used to me.  On the end that contacts the valve stem.  Double check me.
Posted 5 Years Ago
Last Active: 6 days ago
panel driver (3/26/2020)
Somebody on this Site is/was selling those Rockers on Ebay. I assume Adjusters are not included.
Posted 5 Years Ago
Posts: 3.7K, Visits: 497.8K
erased
Cliff
Posted 5 Years Ago
Their mine, I still have about 15 sets, they are all brand new, the pictures are with my dirty hands. the boxes I sell are nicer. I started with about 40 sets, almost all gone, these are the lock nut type.
I sold a set to Ted, ask him about them.
Posted 5 Years Ago
Cliff (3/26/2020)
How much are they buying direct from You? Its costing You at least 20% to sell on Ebay. The Instructions with the Arms indicate they should be used on Intake Valves only. Anyone know why?
