Visits: 190.0K
JUST REPLACED MYN,ORING IN GASKET KIT ROUND, THE 1 I REPLACED WAS SQUARE. WHAT IS CORECT
Last Active: 7 hours ago
Visits: 442.9K
Square is correct. Either should work.
Posts: 7.5K,
Visits: 205.8K
I have had zero issues using the round o rings that are supplied in the Best Gasket gasket sets for the gerotor oil pumps. I do lube those gaskets with lithium or white grease before putting the oil pump cover in place.
Visits: 190.0K
THANKS THAT IS WHAT I DID AND SEEMS TO DO THE TRICK
