JUST REPLACED MYN,ORING IN GASKET KIT ROUND, THE 1 I REPLACED WAS SQUARE. WHAT IS CORECT
Square is correct. Either should work.
By Ted - 5 Years Ago
I have had zero issues using the round o rings that are supplied in the Best Gasket gasket sets for the gerotor oil pumps. I do lube those gaskets with lithium or white grease before putting the oil pump cover in place.
THANKS THAT IS WHAT I DID AND SEEMS TO DO THE TRICK
