57-60 distributors
Posted By Dave V 5 Years Ago
Posted 3 Years Ago
For help, go to the members list & look for RB.  you may be able to e mail him re Lincoln stuff.  He may even have a 4 Bbl intake available..
B-rad
Posted 3 Years Ago
Supercharged (861 reputation)Supercharged (861 reputation)Supercharged (861 reputation)Supercharged (861 reputation)Supercharged (861 reputation)Supercharged (861 reputation)Supercharged (861 reputation)Supercharged (861 reputation)Supercharged (861 reputation)
Last Active: 13 hours ago
Posts: 334, Visits: 1.5K
Thanks Miker, there is a lot of good info there. People kept telling me a 57 or newer distributor or intake but I didn't know if I should look for Ford or lincoln. Now I'm writing stuff down for easy retrieval. Lost a lot of good info I was given on here, unable to find it again. I hope to connect with a couple of LYB afficianatos I was told of on here. This is my first car rebuild, guess I picked an odd ball.
Brad
Sierra Vista Arizona
1954 Lincoln Capri
Posted 3 Years Ago
Last Active: 6 days ago
Posts: 1.8K, Visits: 194.2K
Here’s a very old post on the HAMB regarding these engines and the limited interchange. 3 pages, I didn’t read the whole thing. But post #18 addresses the oil pump. Probably good info further down.
https://www.jalopyjournal.com/forum/threads/running-y-blocks-lincoln-engines.206174/
B-rad
Posted 3 Years Ago
Can someone please answer this question....
When I look for the hex drive oil pump, would that be a Ford or lincoln or either? Must be from/for a 8 cylinder?
That's so I can change from original distributor to the 57 and up. Would that distributor be Ford or lincoln or either? From 8 cylinder?
Brad
1954 Lincoln Capri
B-rad
Posted 3 Years Ago
I asked the seller for pic and cu in info. I tried looking up the topic number but couldn't find it
Brad
1954 Lincoln Capri
Posted 3 Years Ago
Posts: 1.2K, Visits: 1.8K
In all probability, the 1963 F600 engine is a 292; the intake won't fit your 317. However, if the F600 has a 332 (unlikely), the intake will fit. An easy way to determine is by asking the seller to send a photo of the intake ports; if they're stacked, it's a 292.
Posted 3 Years Ago
B-rad, Topic 148025 should answer your question.
B-rad
Posted 3 Years Ago
The oil pump and drive needs to be a Ford or lincoln? Someone is selling a 4v intake from a 63 f600. Do you know if that'll work on my LYB?
Brad
1954 Lincoln Capri
Posted 3 Years Ago
Last Active: 12 hours ago
Posts: 7.4K, Visits: 205.6K
B-rad (6/22/2022)
Would you know if this is the distributor I need on my 54 Lincoln 317? I might want to switch from the stock carb and understand that I have to get a newer distributor too
Your question would get more traffic as a new post in the technical section and not the classifieds.
The Ford Y distributors will work on the Lincoln Y engines providing the distributor gears are changed out.  The 1954 FYB and LYB distributors do use a slotted oil shaft versus the 1955 and newer distributors using a ¼” hex shaft.  If trying to retain the original slotted oil drive, then you would need the 1954 Ford/Merc FYB distributor and not the later model one.
If wanting to upgrade the distributor to something newer than the original Load-O-Matic then the oil pump and oil drive can be changed out to the hex drive types and any 1957 and newer Y distributor can be made to work.  I have been told that the LYB distributor gears are the same as the 352-390-428 FE Ford engines but I have not verified that.
Posted 3 Years Ago
Here's another issue to contend with: the 55-up Y-block distributors use a hexagonal distributor driveshaft. Earlier distributors did not. Swapping distributors, in this case, would also require swapping oil pumps as well.
