Connecting Rod Bolts
Posted By 55 GLASS TOP 5 Years Ago
55 GLASS TOP
Posted 5 Years Ago
Posts: 389, Visits: 31.8K
Hello , can I knock the bolts out with a hammer to change them or must they be pressed out thanks
darrell
Posted 5 Years Ago
Posts: 453, Visits: 22.1K
they are easy to knock out
Posted 5 Years Ago
Last Active: 8 hours ago
Posts: 6.1K, Visits: 441.3K
You have to have the big end resized.  Let the machine shop handle it, unless you just want  to remove them.
Posted 5 Years Ago
Posts: 7.4K, Visits: 205.0K
Charlie beat me to the post but I'll add a bit more detail.
Be aware that removing the bolts from the rods and reinstalling the bolts again requires that the connecting rod big ends be resized.  For a quick test on this, just knock out the bolts in one rod, put the bolts back in the opposing holes, re-torque the nuts with the cap in place, and then measure the hole.  You’ll now find it out of round.  You may not even have to measure the hole if you feel a staggered lip at the bearing hole parting lines.
55 GLASS TOP
Posted 5 Years Ago
So if I do not change the bolts I do not have to have the rods resized
Posted 5 Years Ago
Depends on what U intend to do with the engine. If  they are probably original & any kind of higher performance is planned, best follow what has been recommended here & also replace them..
Posted 5 Years Ago
Posts: 1.2K, Visits: 285.6K
Don't use 60+ year old rod bolts.   Use ARP bolts and have the rods resized and bushed.  These engines are old.  Your mains are probably out of align too.
Posted 5 Years Ago
55 GLASS TOP (1/15/2020)
If the bolts are removed from the rods and regardless if the same bolts or new ones are reinstalled, rod big end resizing is required.
55 GLASS TOP
Posted 5 Years Ago
Just ordered a set of ARP bolts I will get the rods resized as advised thank you . This is why I come here for the knowledge
Posted 5 Years Ago
Be aware that ARP offers two different bolt sets for the Ford Y rods.
The 154-6004 bolt set is for the ECZ, C1TE, & C2AE rods.
The 154-6005 bolt set is for the EBU rods.
