torque converter bolt
Posted By mjs 6 Years Ago
mjs
Posted 6 Years Ago
Posts: 84, Visits: 123.8K
So while I had my transmission and torque converter out to be rebuilt I lost one of the torque converter bolts and nut.  I've looked everywhere for it but cannot locate it.  Anybody know where I can source a replacement?  Any help would be much appreciated.
http://forums.y-blocksforever.com/uploads/images/a3ce7c66-5c01-4c31-91a6-8019.jpg
http://forums.y-blocksforever.com/uploads/images/1d5b145a-1c57-4c0d-8bd1-fba5.jpg
Posted 6 Years Ago
Last Active: 6 hours ago
Posts: 1.8K, Visits: 306.3K
What are you working on?
mjs
Posted 6 Years Ago
It's a 1957 Lincoln Premier.  The bolt holds the two halves of the torque converter together as well as to the flex plate.
Posted 6 Years Ago
Where are you at?
mjs
Posted 6 Years Ago
I'm in Spokane.
Posted 6 Years Ago
I don't know if you and Ted got together, so here are the PN's -
http://forums.y-blocksforever.com/uploads/images/7bf3773f-96de-450b-94f3-036e.jpg
http://forums.y-blocksforever.com/uploads/images/6d2f0f85-584a-452d-92d7-55be.jpg
http://forums.y-blocksforever.com/uploads/images/46f5224c-107f-4a41-9746-cc65.jpg
http://forums.y-blocksforever.com/uploads/images/fe4c0b55-d49a-4e6d-9dc6-d3b4.jpg
Posted 6 Years Ago
Posts: 3.6K, Visits: 497.7K
If Ted doesn't have one, I recommend you contact some one in a Lincoln club for it.  Any chance it is the same as a Fordomatic??
Posted 6 Years Ago
It appears to be the same for the MERC-O-MATIC but a different size for the FORD-O-MATIC -
http://forums.y-blocksforever.com/uploads/images/78fe3f14-a9e3-4784-ab78-3d9e.jpg
http://forums.y-blocksforever.com/uploads/images/8e07e7da-f92e-4b5d-acc6-5ad4.jpg
Posted 6 Years Ago
Posts: 3.7K, Visits: 323.0K
If you can't find another bolt, what I would do is use a standard hex head bolt, nut, and lockwasher.  Then 180 degrees from that replacement bolt I would remove the original bolt and install exactly the same combination as the replacement bolt/nut to assure the balance of the converter.
Brent
Posted 6 Years Ago
Last Active: 8 Months Ago
Posts: 142, Visits: 1.5K
The bolts appear to be the same as my '55 T-bird, Hill's Thunderbird catalog shows:
*7964-A Bolt Ring Gear to Air Cooled Torque Converter ....... Call
*7964-B Bolt Ring Gear to Water Cooled Torque Converter .. Call *
