Transmission Questions
Posted By customline3859 7 Years Ago
customline3859
Question Posted 7 Years Ago
Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)Supercharged (214 reputation)
Posts: 80, Visits: 979
I have an AOD transmission that I'm going to run with a 304ci Y-block. I've located the correct TV cable from Lokar, but I'm not sure about the corrector bracket for the carb, or if I even need one. I have a 3x2 carb setup with a progressive linkage. They are ford carbs. Does anyone know which bracket I am in need of. Here's a photo of my intake setup for reference.
Thanks,
David
http://forums.y-blocksforever.com/uploads/images/2bc2254a-7ade-4468-b32f-6428.png
Last Active: 10 hours ago
Posts: 4.6K, Visits: 39.3K
I used a Lokar cable and bracket and a Lokar transmission adapter. On the AOD adjustment of the TV cable is a must. If its wrong the transmission can burn up in a few blocks. There are a number of sites that will show you how. You will need a pressure gauge to hook up to the trans. I'm running one and it been right on for about 10 years. Will you be using your stock column shift? It can be made to work. https://www.speedwaymotors.com/Lokar-KD-2AODU-Ford-AOD-Black-Kickdown-Cable,64968.html
