Visits: 2.4K
I have a Ford Y block exhaust manifold that starts ECU. In checking the information I find this is supposed to be from a 1955 Lincoln, but the Lincoln uses a staggered bolt pattern and this is straight like the Ford Y block manifold and looks exactly like the Ford and not the Lincoln. Does anyone have any information as to year and model? It is definitely a left manifold.
Visits: 22.9K
What is the rest of the number? Suffix? Any other numbers such as a date? Joe-JDC
Posts: 1.9K,
Visits: 306.4K
Are you sure the PREFIX is ECU? ECU identifies as a 56/57 LYB 368
Visits: 323.7K
My guess if the casting number is ECJ, not ECU.
Visits: 2.4K
Thanks, I will look at it again, It is definitely a Ford bolt pattern, NOT Lincoln.
