By cokefirst - 7 Years Ago
I have a Ford Y block exhaust manifold that starts ECU. In checking the information I find this is supposed to be from a 1955 Lincoln, but the Lincoln uses a staggered bolt pattern and this is straight like the Ford Y block manifold and looks exactly like the Ford and not the Lincoln. Does anyone have any information as to year and model? It is definitely a left manifold.
By Joe-JDC - 7 Years Ago
What is the rest of the number? Suffix? Any other numbers such as a date? Joe-JDC
By KULTULZ - 7 Years Ago
Are you sure the PREFIX is ECU?
ECU identifies as a 56/57 LYB 368
My guess if the casting number is ECJ, not ECU.
Thanks, I will look at it again, It is definitely a Ford bolt pattern, NOT Lincoln.
