54 passenger converted to 12v , which headlight switch to use ??
Posted By a5043@netzero.net 7 Years Ago
a5043@netzero.net
Question Posted 7 Years Ago
Normally aspirated (46 reputation)Normally aspirated (46 reputation)Normally aspirated (46 reputation)Normally aspirated (46 reputation)Normally aspirated (46 reputation)Normally aspirated (46 reputation)Normally aspirated (46 reputation)Normally aspirated (46 reputation)Normally aspirated (46 reputation)
Posts: 14, Visits: 270
can i use a 56 passenger headlight switch in my 54 ??  i wish to retain the dash light dimmer capability .
Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)Supercharged (6.2K reputation)
Posts: 3.7K, Visits: 32.9K
When I converted my 53 Years ago I used the original Switch. You will need to disconnect the Wire to Resistor for Dash Lights and run direct 12 Volts from a Terminal on Switch.The dimmer will no longer work but U will have bright Dash Lights. Otherwise use One from a 12 Volt Car like 1956.
Last Active: 4 days ago
Posts: 3.7K, Visits: 498.0K
My 54 has the original switch.  I always keep the dash light bright so not sure the dimmer even works.  In addition, I put LED's in for all the dash bulbs.
