55/56 Ford Thunderbird Wheels and Sedan Wheels - differences?
Posted By Daniel Jessup 7 Years Ago
Daniel Jessup
Posts: 2.0K, Visits: 131.2K
like the title says, does anyone know the differences between original 55/56 Ford Thunderbird wheels and 55/56 Ford Sedan Wheels? I picked up two 15" Tbird wheels (was told anyway - there is a "FoMoCo" and a "KH" stamped on them). The bolt pattern check out for sure.
Daniel Jessup
Red Lion, Pennsylvania
Oldmics
Posts: 710, Visits: 78.1K
55 & 56 T Bird wheels are as you already know 15".
They are 5" from inside bead to outside bead.They used rivets to secure the inner wheel to the outer wheel.They also have 4 slots that appear between the center rim and the outer rim.
_______________________________________________________________________________________________________________-
Passenger car wheels and 6 passenger station wagon wheels are also 5" from bead to bead.
UNFORTUNATLY I dont know any other differences BUT can tell you that there are differences as the Bird wheels have a different part number than passenger car wheels.
Probably a differences in the wheel offset.
Oldmics
Dan, the KH simply stands for Kelsey Hays, the Co. that made them.
Lou
Last Active: 4 Months Ago
Posts: 564, Visits: 8.4K
Kelsey Hays also made the Thunderbird bodies.
Oldmics
Budd made the 55-57 T Bird bodys as well as the sheet metal parts for replacement.
Oldmics
Lou
Woops, sorry Olds , your right, My bad.
