Visits: 3.5K
The 3 speed transmission in the '56 Ford won't shift It seems to be stuck (locked) in 3rd gear. It will run down the road in 3rd but it won't go into 1st, 2nd or reverse. Any body out there know the problem(s) I did squirt some grease in the fitting on top of the shift column, and added washers to the transmission arms where the leavers hook-up. Thanks in advance, Tim Florida West Coast 33706
Last Active: 18 minutes ago
Posts: 1.0K,
Visits: 164.2K
I have the same problem. I’ve dropped the transmission, hope to start disassembly tonight. The input shaft is locked up to the output shaft. I found a little piece of metal that looks like part of the hub insert on the synchronizer assembly. I have no chipped or broken gears. I was about a mile from home, pulled up to a stop sign and it was locked in 3rd. I need the truck in 2 weeks. Hope to get it done.
Dennis in Lititz PA
Visits: 285.6K
Remove the two nuts that hold the shift arms to side of the transmission and try to shift the transmission with a 3/8 wrench. Both the front and rear arm should have three detent positions. The center position is neutral. In neutral you should be able to turn the driveshaft. If the transmission shifts with a wrench, the problem is most likely in the column linkage. If it doesn't, you have broken parts in the transmission itself. The weakest part of these transmissions was 2nd gear. These transmissions are not difficult to work on if you have some mechanical aptitude. You will need a good shop manual.
Posts: 1.0K,
Visits: 164.2K
Well I found my problem. My input shaft bearing is broken.
Dennis in Lititz PA
Visits: 285.6K
Nice. Normally it's the cluster gear.
Visits: 3.5K
Thanks Phil, I'll try that this AM Tim West Coast, Fl 33706
Visits: 3.5K
Phil Monday 10:50 AM. So, undid the linkage and started trying to get the tranny arms in neutral. After pulling,prying, moving the driveshaft (for 2.5 hours)............it now shifts effortlessly. For how long ?????????? Going to review problem tomorrow with and old school mechanic here in St Pete. Again, Thanks, Tim Waiting Room for Heaven, Florida 33706
Visits: 154.2K
Likely the synchros are worn out (modern lube use aggravates the issue). When my ‘55 BW OD started getting stuck in gear 15 yrs ago, I had an old-school mechanic rebuild it. But, I also tracked down all the NOS parts for him first. Luckily, the sun gear assembly was still good, as those parts are really hard to locate (?).
6 VOLTS/POS. GRD. NW INDIANA
Visits: 285.6K
Here's the lube I use in my T86 O/D transmission.. I buy it at Tractor Supply.
Posts: 2.0K,
Visits: 130.9K
Ditto, Florida Phil. I run the exact same oil in my 3 speed/R10 OD transmission.
