Thermostat bypass on FE engines
Posted By Bobwanna 6 Years Ago
Bobwanna
Posted 6 Years Ago
Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)Supercharged (309 reputation)
Last Active: 4 Months Ago
Posts: 108, Visits: 5.8K
I apologize for straying from the Y block but I have a question regarding the FE water pump and bypass system. I have read past posts here that some of you place a restrictor in the Y-block bypass hose. I recall it is 3/16".  This modification reduces the heated water that just goes back into the block and bypasses being cooled by the radiator. This makes sense to me.
OK, on to my FE. I will need to replace the water pump in my 67 F250 with a 352. Since the bypass system is so similar to the Y I was thinking to do the same modification. With pump removed now would be the perfect time. I was wondering if any of you have done this or do you think it is a good or bad idea Thank you - Bob
AKA   Bob-93021
Threaded View
Threaded View
Forum Post Thermostat bypass on FE engines By Bobwanna ( 6 Years Ago )
Forum Post I tried it and then pulled it out. Didn't find it did much. If You... By oldcarmark ( 6 Years Ago )
Forum Post [quote]This modification reduces the heated water that just goes back... By KULTULZ ( 6 Years Ago )
Forum Post MAIN REASON FOR BYPASS IS 1 STOP WATER PUMP CAVITATION 2 KEEP WATER... By 2721955meteor ( 6 Years Ago )
Forum Post I feel its a fix if you are having problems. I was with a Y and had to... By DryLakesRacer ( 6 Years Ago )
Forum Post Olcarmark, Thanks for the input on the restrictor. Was that on you... By Bobwanna ( 6 Years Ago )
Forum Post [quote][b]Bobwanna (8/17/2019)[/b][hr] Olcarmark, Thanks for the... By oldcarmark ( 6 Years Ago )
Forum Post KUL, I was curious on why the bypass was 5/8. I guess to allow decent... By KULTULZ ( 6 Years Ago )
Forum Post The 54 239 also had a smaller water pump. By pintoplumber ( 6 Years Ago )
Forum Post I wouldn't change anything until I know how it does with everything... By charliemccraney ( 6 Years Ago )
Forum Post KUL, I was curious on why the bypass was 5/8. I guess to allow decent... By Bobwanna ( 6 Years Ago )
Forum Post Charlie, I am thinking maybe put it together as factory built since it... By Bobwanna ( 6 Years Ago )
Forum Post Since '55 and up pumps are bigger, maybe they flow more and the larger... By charliemccraney ( 6 Years Ago )
Forum Post I tried the bypass in my Tbird. Besides the restrictor, you have to... By paul2748 ( 6 Years Ago )
Forum Post [quote]So there may be circumstances where the end user finds it... By KULTULZ ( 6 Years Ago )
Forum Post Search for posts by greenbird56 on the subject. The idea is to direct... By charliemccraney ( 6 Years Ago )
Forum Post Guys, I am sure glad I posted my question on the restrictor here.... By Bobwanna ( 6 Years Ago )
Forum Post If it uses the same Diameter Stat as Y Block there is a very... By oldcarmark ( 6 Years Ago )
Forum Post [QUOTE]Search for posts by greenbird56 on the subject[/QUOTE] My... By KULTULZ ( 6 Years Ago )
Forum Post [quote]The 54 239 also had a smaller water pump. Dennis in... By KULTULZ ( 6 Years Ago )
Forum Post If it uses the same Diameter Stat as Y Block there is a very... By Bobwanna ( 6 Years Ago )
Forum Post It is a bird but if I'm remembering right, a part of the changes was... By charliemccraney ( 6 Years Ago )
Forum Post [quote]It is a bird but if I'm remembering right, a part of the... By KULTULZ ( 6 Years Ago )
Forum Post For TBirds, CASCO has a water pump with longer vanes to help coolant... By paul2748 ( 6 Years Ago )
Forum Post You can't keep moving the goal post. Sure, repositioning the pulley... By charliemccraney ( 6 Years Ago )
Forum Post How is any goal post being moved? Trying to have a simple... By KULTULZ ( 6 Years Ago )
Forum Post Bypass restriction works fine on my outfit - for desert use here in... By GREENBIRD56 ( 6 Years Ago )
Forum Post Steve, Was beginning to wonder if you were still around, and sane ! By pegleg ( 6 Years Ago )
Forum Post Hi Frank! I got a "retirement" job as a supervisor in a machine shop -... By GREENBIRD56 ( 6 Years Ago )
