Visits: 78.1K
I personally look for engines that were from automatic trans vehicles. Wagons and 4 doors are always a good pick. I have found over the years that the rear main block is prone to cracking due to the replacement pressure plates being too strong or incorrectly replaced - especially on 312s .
My .02$ !
Oldmics
Last Active: 4 Weeks Ago
Visits: 32.6K
I had a local Guy contact Me through Kijiji. He has a Transmission also which doesn't interest Me unless its an early 60's Cruisematic. Supposed to get back to Me with more Information. Year and type of Transmission.
Visits: 2.9K
I have a small case cruise-o-matic I'd like to get rid of. It's from a 61-62 car with a 292. Converter and bellhousing included. No flexplate
Visits: 2.9K
hi i have 2 sets of 312 pistons still in the box that i want to sell but i am in oz. cheers
Visits: 13.5K
Hi, where are you? (with the cruise o matic)
Visits: 23.2K
Visits: 2.9K
I'm in Parma, Ohio. Right around the corner where Drew Carrie is from! I also travel to Cleveland Tenn about 3 times a year. I also have a 292 block that I ran for about a month in my truck last year. It definetly needs a rebuild.
Visits: 13.5K
I would like to buy the bell housing (if it's aluminum), I live in California
Posts: 3.3K,
Visits: 238.8K
Mark: A 312 is likely the riskiest to buy, due to the possibility of the block being cracked at the mains. Don't buy it if you can't get a good look at a clean block area, and or a bill for testing. Also, Ted E. has indicated that some 312 blocks have cam journal alighnment issues, that may require re machining. Besides, if you just have to have the xtra inches, John Mummert sells a 292 to 312 conversion kit now. No 312 crank required.. Good luck.
Visits: 32.6K
Thanks Paul. A 292 would be sufficient if I find a good One.
