Oil Pickup Tube
Posted By Jack Groat 6 Years Ago
Jack Groat
Question Posted 6 Years Ago
Last Active: 5 Months Ago
Posts: 142, Visits: 1.4K
This is an easy one for you Y-block experts.  I bought an oil pan with attaching pickup tube on ebay.
The end of the tube where it goes into the oil pump has a sizable dent, almost looks like it was put there using a die.
So my question is:  Does that dent belong there??  Photos attached.,http://forums.y-blocksforever.com/uploads/images/ff071831-aff1-43f2-8413-ab64.jpghttp://forums.y-blocksforever.com/uploads/images/a4ea6d92-e2d8-4f74-b4dd-5dc3.jpg
Posted 6 Years Ago
Last Active: 16 minutes ago
Posts: 3.7K, Visits: 323.2K
No.
Cliff
Posted 6 Years Ago
Posts: 879, Visits: 13.5K
I see that all the time, don't know why, I beat it back straight with a steel dowel and a hammer
bergmanj
Posted 6 Years Ago
Posts: 257, Visits: 3.9K
Probably from overtightening of the nut onto the rubber seal.  Was done a lot to try & fix leaks [air-in when running or oil out when parked/off] there. Overtightening just made it worse; then, to the point of collapse as you see on your pickup pipe as pictured.
Regards, JLB
