Visits: 97
I have a 1955 T Bird with stock 292. I have acquired a '57 intake manifold and need to know which new carburetor to purchase. I'd like to use a '57 T-Bird air cleaner with the new carb. Is that possible? I also have what appears to be a 1957 distributor with tach drive. The part # on the distributor is EJ 12127 A2. However, i don't see that part # listed on Mummert's list of desirable distributors. Is it the right distributor for the upgrade? Thanks for your help.
Steve
Steve
Visits: 97
It's hell getting old! Just looked at the distributor with a magnifying glass. The part # is FEJ 12127 not EJ 12127 as i had originally posted. Mummert lists 1957-59 distributors that are desirable as FEH or FEJ so i am still wondering if what i have is good for the upgrade.
Thanks again.
Steve
2 or 4v? Remove the distributor cap. If you see advance springs, its not what you want to use. If you do not see advance springs, it is what you want.
Visits: 97
Thanks Charlie. It has no springs visible. I'm wanting to use a 4v carb and manifold...…….looking at the Summit M2008 Series Carburetors, 500cfm.
Steve
Posts: 1.8K,
Visits: 306.3K
FEJ 12127 A2 is original to a 1957 BIRD 292/312 Tach Drive It is Dual Advance. Service PN is B7S 12127-A if needed.
