By 55ebird - 6 Years Ago
I have a 1955 T Bird with stock 292. I have acquired a '57 intake manifold and need to know which new carburetor to purchase. I'd like to use a '57 T-Bird air cleaner with the new carb. Is that possible? I also have what appears to be a 1957 distributor with tach drive. The part # on the distributor is EJ 12127 A2. However, i don't see that part # listed on Mummert's list of desirable distributors. Is it the right distributor for the upgrade? Thanks for your help.
Steve
It's hell getting old! Just looked at the distributor with a magnifying glass. The part # is FEJ 12127 not EJ 12127 as i had originally posted. Mummert lists 1957-59 distributors that are desirable as FEH or FEJ so i am still wondering if what i have is good for the upgrade.
Thanks again.
2 or 4v?
Remove the distributor cap. If you see advance springs, its not what you want to use. If you do not see advance springs, it is what you want.
Thanks Charlie. It has no springs visible. I'm wanting to use a 4v carb and manifold...…….looking at the Summit M2008 Series Carburetors, 500cfm.
By KULTULZ - 6 Years Ago
FEJ 12127 A2 is original to a 1957 BIRD 292/312 Tach Drive
It is Dual Advance.
Service PN is B7S 12127-A if needed.
