flywheel
Posted By emtdude56 6 Years Ago
emtdude56
Posted 6 Years Ago
Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)
Posts: 46, Visits: 136
are 272 and 312 flywheels interchangeable thanks
Posted 6 Years Ago
Last Active: 12 minutes ago
Posts: 6.1K, Visits: 442.8K
All Ford Y-Blocks use the same crank flange pattern so in that sense, all are interchangeable.  However, different size clutches were used for some so the pressure plate pattern could be different.  Also, because of the interchangeability, it can have anything in it right now so the only way to know what you have with certainty is to pull it apart.
Posted 6 Years Ago
Last Active: 2 Weeks Ago
Posts: 1.9K, Visits: 194.9K
Charlie, by chance do you know if the weights are the same? At least for cars and light trucks?
Posted 6 Years Ago
I don't know.  I'm pretty sure they are the same weight.
