yknot
Visits: 7.3K
Which FE fuel pump will fit a 57 292. I did a quick search. I just couldn't find it.
59FE258Y
Visits: 245
Rockauto has the same fuel pumps listed for a 1957 Fairlane 292 and a 1958 Fairlane 352 FE.
Last Active: 6 hours ago
Visits: 39.4K
The early FE's are the same pump. I ran a 427 high performance pump on my Y for years.
yknot
Visits: 7.3K
Thanks guys. It was stuck in my head that it had to be a specific pump.
Posts: 3.8K,
Visits: 33.2K
Any of the early 60's 352 390 427 Pumps fit. Rock Auto sells One with the Filter in the Canister on the Pump. Carter M4008. I have used that One before. Remember the Arm goes below the Camshaft not on top of it. .
Rono
Posts: 1.3K,
Visits: 80.0K
Edelbrock Performer #1724 fuel pump for FE motors.
Ron Lane, Meridian, ID
Visits: 498.2K
IS this correct? It seems to me that the arm goes under the eccentric. Have I been doing it wrong all these years? oldcarmark (7/9/2019)
Any of the early 60's 352 390 427 Pumps fit. Rock Auto sells One with the Filter in the Canister on the Pump. Carter M4008. I have used that One before. Remember the Arm goes on TOP of the Camshaft not below it..
Rono
Posts: 1.3K,
Visits: 80.0K
Paul; What do you mean? Fuel pump arm has to go under the eccentric.
Posts: 3.8K,
Visits: 33.2K
Rono (7/9/2019)
Paul; What do you mean? Fuel pump arm has to go under the eccentric. Thanks Paul and Rono. I just realized my Error. Sorry. Should be under the camshaft not on Top. Brain Freeze!!
Posts: 3.3K,
Visits: 238.8K
A side note on the F.E. pumps. The main difference from the y-pump is that it doesn't have the vacuum booster for '57 & prior original wipers.. P.S.- Old car mark, you can edit your post & correct it if you want..
