chipped block
Posted By DiLL 6 Years Ago
DiLL
Posted 6 Years Ago
Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)
Posts: 29, Visits: 17.6K
So this happened. My fault, bolt was too long. What is going to be the best way to address this? Will the bell housing hold with just 3 secure bolts? Any advice would be great!
DiLL
Cliff
Posted 6 Years Ago
Posts: 879, Visits: 13.5K
Weld it, an easy job
Posted 6 Years Ago
Last Active: 12 hours ago
Four bolts are marginal for bellhousing retention so you need all four.  The broken piece can be welded back on but needs to be performed with a bolt in the hole to insure thread alignment.  That hole might require a helicoil if the threads miss a little bit.  Another fix is to weld up the broken area solid and then redrill the bellhousing hole.
