By DiLL - 6 Years Ago
So this happened. My fault, bolt was too long. What is going to be the best way to address this? Will the bell housing hold with just 3 secure bolts? Any advice would be great!
By Cliff - 6 Years Ago
Weld it, an easy job
By Ted - 6 Years Ago
Four bolts are marginal for bellhousing retention so you need all four. The broken piece can be welded back on but needs to be performed with a bolt in the hole to insure thread alignment. That hole might require a helicoil if the threads miss a little bit. Another fix is to weld up the broken area solid and then redrill the bellhousing hole.
