Vacuum ports??
Posted By seishank65 6 Years Ago
Posted 6 Years Ago
Posts: 1.9K, Visits: 194.9K
This is the link to the Edelbrock manual. Down at page 21it shows an diagram. #50 is ported vacuum and 51 is full vacuum. 51 is where I’d hook the vacuum gauge for tuning purposes. Either can be used for the distributor, personal preferences vary.
https://www.edelbrock.com/pub/media/wysiwyg/documents/carb-owners-manual.pdf
seishank65
Posted 6 Years Ago
Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)
Posts: 34, Visits: 2.5K
Thanks everyone for their input and fast replies
seishank65
Posted 6 Years Ago
miker I currently have my distributor plumbed into this port (51), for tuning purposes can i just unplug the dizzy vacuum line and plug in my vacuum gauge?
Posted 6 Years Ago
Short answer is yes, but I’d prefer to use a tee. I like checking and tuning with the vacuum advance in the running position. If you unplug the distributor, you’ll find the loss in advance slows the engine down, and you might have to add to the idle speed.
I’d do a search for ported and non ported vacuum. Lots of folks here, including Ted, IIRC, run the ported vacuum to the distributor. I’d try that, retune for it, and take it from there. Or, if you’ve been down that road, use a tee to put the vacuum gauge in.
seishank65
Posted 6 Years Ago
Thanks miker I really appreciate your help
Posted 6 Years Ago
See if these pictures help.
http://forums.y-blocksforever.com/uploads/images/30064ced-bd81-4525-8ef2-5229.jpg
http://forums.y-blocksforever.com/uploads/images/1ae128e7-e4f7-43f7-b701-120c.jpg
http://forums.y-blocksforever.com/uploads/images/0e798ce6-525b-4c58-ae28-d3bb.jpg
seishank65
Posted 6 Years Ago
Thanks Ted a picture says a thousand words.
Posted 6 Years Ago
Last Active: 10 days ago
Just a Heads Up. If U are not using the old Choke Setup in the Manifold there is a Tube inside the Manifold  that connects the Fitting on One Side to a Fitting on the other Side. Those Tubes rust out over the Years and will cause a Vacuum Leak if not Plugged on both Ends. I tapped both Sides and screwed a Bolt in to Plug it. You might want to do that and avoid Vacuum Leaks at some Point if not now.
