Water temp gauge
Posted By 55charliebird 6 Years Ago
55charliebird
Posted 6 Years Ago
Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)Supercharged (600 reputation)
Posts: 192, Visits: 39.2K
I cant seem to find a water temp gauge, mechanical stud type, to fit a 3/8 npt fitting.  Most of them have a capillary tube and require electrical connections.  I want a gauge that reads from 100 to 280 degrees so that the 200-220 degree is somewhat in the center of the sweep.  That is usually the accuracy area.  Any ideas, brand, etc.  I intend to install it in a "T" fitting at the heater valve area, directly in front of the carb.
Posted 6 Years Ago
Last Active: 2 Weeks Ago
Posts: 1.9K, Visits: 194.9K
55, I don’t understand the question. In my experience a mechanical gauge with a capillary tube only has an electrical connection for a light in the gauge. Electrical gauges have a sensor into the water passage, power to the gauge, wire from the gauge to the sensor, it acts as a variable ground. Finding an electrical sensor (aftermarket type) I. Smaller pipe sizes NPT, or metric is one thing. The mechanical capillary type tend to be larger. Been years, but I seem to remember them at 3/8 NPT.
Robs36Ford
Posted 6 Years Ago
Supercharged (229 reputation)Supercharged (229 reputation)Supercharged (229 reputation)Supercharged (229 reputation)Supercharged (229 reputation)Supercharged (229 reputation)Supercharged (229 reputation)Supercharged (229 reputation)Supercharged (229 reputation)
Posts: 82, Visits: 335.0K
?? Are you asking for a gauge like the ones in a rad cap? Used in the 1930's and older cars. Also modern ones are made for racing. Never seen any that can be threaded in though.
1936 Ford 3W Coupe : 56 T-Bird 312, 47 Packard 3 speed, 40 juice brakes.
1968 Merc Cyclone FB GT 390, Getting a better front clip!
1977 Ford F-250 Supercab RWD Explorer Long box.
1976 Chev Camaro RS LT
Future rebuild : 1949 Ford F-1
55charliebird
Posted 6 Years Ago
Basically it is the same type gage that you would find in a hot water boiler system that is used in a home heating system.  It screws into a female receptacle pipe fitting.  It has a metal "stud", if you will, that senses the water temp.  I guess I need to find a plumbing supply company here in Fla.  Thanks for trying.  Charlie
55charliebird
Posted 6 Years Ago
I found several on different websites.  I narrowed it down to one from amazon.  Problem solved.  Thanks
Posted 6 Years Ago
Posts: 3.6K, Visits: 497.7K
Can you give us the  make and model #?
55charliebird (6/14/2019)
Posted 6 Years Ago
I understand now. I used one of the small Moon ones in the intake manifold right before the ‘stat for years. I don’t remember it being anywhere near this pricey.
https://www.jegs.com/i/VPA/960/49800-VUI/10002/-1?gclsrc=aw.ds&&mrkgcl=1239&mrkgadid=3328194555&adpos=1o1&creative=330726016700&device=t&matchtype=&network=g&jegspromo=nonbrand&gclid=EAIaIQobChMI2fiP1b7q4gIVi_hkCh32PwxoEAQYASABEgJw6_D_BwE
55charliebird
Posted 6 Years Ago
PIC GAUGE TRI-RC-254R1.75D...........ON AMAZON, COST $36.00.   IT HAS TEMP AND PRESSURE.  2 1/2 " DIAL FACE.  THE ONLY ONE I COULD FIND WITH THE 195-210 DEGREE CENTERED IN THE GAGE SCALE.
Posted 6 Years Ago
Oddly enough, It wouldn't come up on Amazon.  But ebay had the same thing, 22.00, free shipping.  Plus another brand (pressure and temp) for less that 20.00
55charliebird (6/15/2019)
55charliebird
Posted 6 Years Ago
I could not find it on E-bay.  Anyway, I found the one I wanted.  Thanks
