Posts: 1.4K,
Visits: 179.6K
Vern does not use the Internet for his business correspondence or marketing. The last heavy wall rocker arm shafts I purchased from him in 2015 were $58.00 per set. These are made of 1018 steel, are heat treated to improve resistance to wear, and have oil slots to improve oil dispersion over the shaft and rocker arm bore surfaces. Schumann's Sales & Service Inc. 227 West Mayne Street P.O. Box 128 Blue Grass, IA 52726 phone - 563-381-2416 Fax - 563-381-2409 Hope this helps!
Posts: 3.3K,
Visits: 238.8K
Schumann Sales in Iowa, as Charlie mentioned, has new H.D. ones apparently. You'll have to search a phone #, he's not on the internet as far as I know. Mummert in El Cajon CA was stocking std & H.D. ones at one time... The H.D. ones have oiling grooves cut into them, if I recall..
Visits: 32.7K
Rock Auto has the Melling Shafts. MUCH less than Macs.
Visits: 190.0K
macks have rocker shafts for 40.00 each
Visits: 190.0K
just block the return tube and they will last for ever
Visits: 497.9K
Look on ebay - there are some on there (new)
Posts: 2.0K,
Visits: 131.0K
ELGIN still makes them I believe.
There's also Schumann Sales.but I don't know the contact info. It looks like Melling is the only supplier so there may be some difficulty in the near future.
Visits: 136
jegs shows them on there site ill have to give them a call
Visits: 136
called mellings&sumit direct the said they were discontinued
