rocker shaft
http://forums.y-blocksforever.com/Topic145934.aspx
By emtdude56 - 7 Years Ago
does any one know if rocker shafts are available in after market mellings still has them in there
catalog but no longer offers them brand or part number would be helpful thanks
Melling MRS-621.
There are some on ebay.  Summit, Jegs, and some local parts stores show them, too.
What makes you say they don't offer them anymore?  Might need to stock up, if that's true.
called mellings&sumit direct the said they were discontinued
jegs shows them on there site ill have to give them a call
There's also Schumann Sales.but I don't know the contact info.
It looks like Melling is the only supplier so there may be some difficulty in the near future.
ELGIN still makes them I believe.
By paul2748 - 7 Years Ago
Look on ebay - there are some on there (new)
just block the return tube and they will last for ever
macks have  rocker shafts for 40.00 each
By oldcarmark - 7 Years Ago
Rock Auto has the Melling Shafts. MUCH less than Macs.
By PF Arcand - 7 Years Ago
Schumann Sales in Iowa, as Charlie mentioned, has new H.D. ones apparently. You'll have to search a phone #, he's not on the internet as far as I know.
Mummert in El Cajon CA  was stocking std & H.D. ones at one time... The H.D. ones have oiling grooves cut into them, if I recall..
By NoShortcuts - 7 Years Ago
Vern does not use the Internet for his business correspondence or marketing.  The last heavy wall rocker arm shafts I purchased from him in 2015 were $58.00 per set.  These are made of 1018 steel, are heat treated to improve resistance to wear, and have oil slots to improve oil dispersion over the shaft and rocker arm bore surfaces.
Schumann's Sales & Service Inc.
227 West Mayne Street
P.O. Box 128
Blue Grass, IA  52726
phone  -  563-381-2416
Fax  -  563-381-2409
Hope this helps!  Smile
