VS57 McCulloch supercharger mounting
Posted By 55F100custom 7 Years Ago
55F100custom
Posts: 6, Visits: 33
I have a VS57 that I am wanting to mount off center to the passenger side of my 62 C2AE 292... I can find some pics on Google but most of them are where its mounted directly in line with the carb. The few I can find for off center are from odd angles of the side that are not yielding good enough view points to begin to fabricate my own brackets... so the question is does anyone have a good source of information or pictures to start. Or does anyone have the magical part numbers for some factory brackets that I could scour the internet for and either buy or attempt to replicate myself? Any help is appreciated
Posts: 1.9K, Visits: 194.9K
Old picture, it’s not on the bird anymore, but something like this?
I can do more pictures, and the brackets and unit are still in the garage.
Last Active: 8 hours ago
Posts: 7.5K, Visits: 205.9K
Another Thunderbird supercharger picture.
http://forums.y-blocksforever.com/uploads/images/0d6fa2f8-53ab-4c5d-8300-d289.jpg
And here are pictures of a supercharger bracket for a 1956 car application.
http://forums.y-blocksforever.com/uploads/images/d7e8238a-2ff2-4dc5-8738-9398.jpg
http://forums.y-blocksforever.com/uploads/images/715edbea-6e42-47c1-bf6e-8de9.jpg
Rono
Posts: 1.3K, Visits: 80.0K
You can contact Gord McMillan of REX Performance. He sells a supercharger kit that mounts the supercharger head off to the right side. I purchased one of his kits a few years back for my 37 coupe project, but when I tried to mount my front fenders, the engine bay was too narrow in the front and I couldn't get the front passenger fender to fit. Here is a picture of the initial mock-up. The kit does include all the brackets, pulleys, bonnet, belt, hardware etc. to set up the system along with detailed instructions and Gord is a good person to work with.http://forums.y-blocksforever.com/uploads/images/44251dd1-5f8a-4fa2-a462-5810.jpghttp://forums.y-blocksforever.com/uploads/images/8f408f3a-0be3-4051-8161-1d88.jpg
55F100custom
Yes something like that! If you have pics from the front of the engine that would be extremely helpful!
55F100custom
Ted- I've never seen that bracket so that is very helpful. I might be able to track one down. ( I try to use original parts as much as possible for the nostalgia and cool factor.
55F100custom
Rono- I will look them up for sure and if I cant locate an original I'll used them. Plus I'm building 2 more 292s so I may end up using Rex's kit... and room wise I think I have plenty in the truck (55 F100)
Rono
I don't have any other straight on frontal shots of that motor set up, but here is two more shots from the left and right front;http://forums.y-blocksforever.com/uploads/images/ba9e21b1-87ef-4d63-9be7-c858.jpghttp://forums.y-blocksforever.com/uploads/images/88ff1dd8-f295-43ba-a73d-ec12.jpg
55F100custom
Rono- that actually helps out more than you'd think. It narrows down the mounting holes. Did you have to brace the back of the supercharger or is it "all willy nilly"
55F100custom
Miker- if you wouldnt mind posting pics I'd greatly appreciate it.
