VS57 McCulloch supercharger mounting
Posted By 55F100custom 7 Years Ago
Posts: 4.6K, Visits: 39.3K
Did you get my PM?
Rono
Posts: 1.3K, Visits: 80.0K
55F100
Gord McMillan provides a complete instruction and installation manual with his kit. It includes all the brackets you need.
j.brandt
Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)
Posts: 1, Visits: 15.7K
Posts: 1.9K, Visits: 195.0K
McC bracket for low left hand side for tbird. I suspect but can’t tell this is the bracket used on the bird picture Ted posted. Bolted to head, had a couple metal straps that went to an exhaust manifold bolt and water pump bolt (I think)
Tension arm for above.
My home made bracket to top Did a pass side mount on the bird, mounted a GM alternator underneath
More homemade bracket. 5 IIRC block/head/water pump mounts. Using a GM diesel front belt idler as tension arm on spring. Single speed drive.
I can supply some more pictures if it’s helpful, send me a pm and I’ll get back to you next week. I think I might have a couple shots with the motor out of the car, but all assembled.
