engine parts wanted
Posted By emtdude56 6 Years Ago
emtdude56
General Posted 6 Years Ago
Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)Supercharged (139 reputation)
Posts: 46, Visits: 136
looking for a cam retaining plate;AN OIL SLINGER :and the nut that goes into the oil pump for the oil pickup tube
thanks
Posted 6 Years Ago
Posts: 6.1K, Visits: 442.5K
The cam retaining plate needs to be thinner than the thrust washer you have.  Measure it.  You will need a caliper or micrometer.  A tape measure or similar will not work.
Or, look for a matched set.
Posted 6 Years Ago
Last Active: 5 hours ago
Posts: 7.4K, Visits: 205.6K
emtdude56 (5/7/2019)
looking for a cam retaining plate; an oil slinger, and the nut that goes into the oil pump for the oil pickup tube
thanks
Where are you at?
emtdude56
Posted 6 Years Ago
hi ted  I am in N.J. if you have the parts sell let me know and I will call you
thanks ken
Posted 6 Years Ago
 I have those three pieces.  It would be nice to know the thickness of the cam thrust washer you have so that the appropriate cam thrust plate can be supplied.  Email me the thickness of the washer and your mailing address and I’ll send you the cam thrust plate, the oil slinger, and the oil pump nut.  My contact information is located at www.eatonbalancing.com .
emtdude56
Posted 6 Years Ago
thanks ted the beveled thrust washer is 194 my worn cam plate is188 I also need if you have
the crank bolt&washer&distribuitor hold down clamp my info is
ken piscitelli
9 canal st Sayreville n.j. 08872  732/407/9825
Posted 6 Years Ago
Posts: 3.6K, Visits: 497.6K
emt - I have a couple of distributor hold down clamps.  Can send you one.  I'm going to out of town from the 13 to the 20th
Let me know.
emtdude56 (5/10/2019)
ken piscitelli
Posted 6 Years Ago
Ken.  I also have the distributor hold down clamp and harmonic damper bolt/washer.  I’ll include those with the other three pieces.  I’ll try to get them packaged up today and on their way to you.  Otherwise they will ship out on Monday for sure.
emtdude56
Posted 6 Years Ago
ted thanks again your a big help received the parts today
emtdude56
Posted 6 Years Ago
thanks but ted bailed me out
