Last Active: 5 hours ago
Posts: 3.8K,
Visits: 33.2K
Quite awhile ago there was a topic regarding Hi Flow Thermostats. One that was mentioned was a Hi Flow 170 Degree Stat from Napa. I got One and it works great. I don't remember the Napa #. Does anyone know the # I am looking for? Something like THM 7 maybe? Thanks I found it. THM 6
Visits: 285.6K
Don't know the NAPA number. I bought mine locally from NPD. It's their part number T-8575-3 $19.60. It's probably available cheaper elsewhere.
Posts: 3.8K,
Visits: 33.2K
I found the Napa # THM6. I have One in mine and it works well. Never could get the Robertshaw Ones to work for some reason. Tried 3 and gave up and bought the Napa One. Friend wants One.
Visits: 498.2K
Yep - THM-6
Ordered from NPD yesterday along with gaskets. Guess I'll finally have the right one this time.
Hey all, I installed the 170* from NPT today any all went very well. Along with the old high-flow 160* Mopar unit it always stuck closed after first startup; it always did open but not until approx 190* and then shot down to what I determined to be 160*. Bugged me but I let it go these last few years. The new one worked in a sauce pan on the stove at 170* and when doing the first test in the car showed water movement with a cardboard in front of the radiator and 169* at the neck of the bypass hose into the top of the water pump. I do have a 1/8" hole in a plug. The new reading on the factory gauge is now about 2 needles with higher than before and where our 56 always ran as I remember in the early 60's.
There is a note in the thermostat box that says you need 1-1/2" between the front of the manifold to heater line and with the dual quad Edelbrock manifold and the deluxe heater vacuum actuated valve there was only 1/2". To make it clear the thermostat only needed to be clocked vertical on it's interior structure as not to interfere with the valve; so all was good.
Next project is to get the speedometer reading correctly after the install of the new Explorer 8.8 with 2.73 gears. The smallest nylon gear i can find is a 19 tooth and 17 is whats needed or maybe even less. I'm working with Rusty @ Speedmeter Service in Colorado (HAMB) and Steve at Texas Electrical Instruments with an adapter to keep it all mechanical and it all looks good and will keep the cost a lot lower that a GPS conversion or GPS to mechanical with these older transmissions..I hate jacking up the car a foot and crawling under but what's a guy to do....
Posts: 3.8K,
Visits: 33.2K
DryLakesRacer (5/1/2019)
Ordered from NPD yesterday along with gaskets. Guess I'll finally have the right one this time. I tried 3 of the Robertshaw Type and never could get them to work properly. I have used the Napa Hi Flow all last Summer and found it worked really well. Consistent Temperature with very little Temperature movement up or down.
I know there are different ones and designs but i really don't remember one from another. I know the "bellows" type would never have fit with the room I had in the manifold. The one I took out was for a Mopar and hi-flow which I was sure I needed back when I was have heating up problems. It may have been marketed thru Mr. Gasket. It had approximately a 1/2" "cup" with 3 oval holes in the bottom and a large opening into the hose housing. The one I received from NPS was in a Casco box and it is the open spring type with a large opening like the first hi-flow and is listed in the NPS catalog as a hi-flow..
Posts: 3.8K,
Visits: 33.2K
DryLakesRacer (5/9/2019)
I know there are different ones and designs but i really don't remember one from another. I know the "bellows" type would never have fit with the room I had in the manifold. The one I took out was for a Mopar and hi-flow which I was sure I needed back when I was have heating up problems. It may have been marketed thru Mr. Gasket. It had approximately a 1/2" "cup" with 3 oval holes in the bottom and a large opening into the hose housing. The one I received from NPS was in a Casco box and it is the open spring type with a large opening like the first hi-flow and is listed in the NPS catalog as a hi-flow.. Sounds like the One sold by Napa. Bigger opening than Standard Stats.
Visits: 498.2K
As far as the speedo gear, what trans are you using? If you are using a 57 or later with the redesigned gear, look for a gear on ebay. If it's an earlier trans, your options are a lot more limited.
