Dumb Question about thermostat bypass hose nipple
Posted By Florida_Phil 6 Years Ago
Posted 6 Years Ago
Posts: 1.2K, Visits: 285.6K
I have a Y-Block thermostat housing that does not have the bypass hose fitting.  Where can I buy this fitting?
http://forums.y-blocksforever.com/uploads/images/7d63c477-1f7e-4c2b-a836-46b6.jpg
Rono
Posted 6 Years Ago
Posts: 1.3K, Visits: 80.0K
Well, I've never seen one without the bypass fitting because I think they are pressed into the housing. The hose end is a 5/8" barb that any good hardware store should have, but the housing I don't believe has threads for a bypass fitting. The outside of the housing looks pretty corroded. How is the inside? If it has a lot of pits I would just get another housing. You don't want any coolant leaks! There are a lot of them out there and they are not that expensive.
57RancheroJim
Posted 6 Years Ago
Posts: 729, Visits: 112.0K
At one time most auto parts stores had the bypass tube, it just presses in. I've seen them on Ebay and I think most T bird suppliers and places like Macs have them.
https://www.macsautoparts.com/ford_mercury_passenger/water-bypass-tube-steel-5-8-od-x-2-1-2-long-v8-ford-only.html
2721955meteor
Posted 6 Years Ago
Posts: 927, Visits: 190.0K
5/8 coper pipe will work   ,best is if you have a oilpump pickup pipe tube, used that, it is correct size and press fit
darrell
Posted 6 Years Ago
Last Active: 5 Months Ago
Posts: 455, Visits: 22.2K
ive used a piece of copper pipe.just put some type of sealer on and press it in.
darrell
Posted 6 Years Ago
got ahead of me
Daniel Jessup
Posted 6 Years Ago
Last Active: 13 hours ago
Posts: 2.0K, Visits: 131.0K
Will this help?
https://www.hotrodreverend.com/single-post/2018/12/01/1955-Ford-Part-63-Rebuilding-a-Thermostat-Housing
Daniel Jessup
Lancaster, California
darrell
Posted 6 Years Ago
you have to come up with these fixes are you end up chasing all over the place.you can wait for weeks for some small part.all part of dealing with obsolete parts.
carl
Posted 6 Years Ago
Posts: 1.2K, Visits: 20.6K
Give me your address and I will send you one   Carl
Posted 6 Years Ago
Done.  Thank you!!
