By Florida_Phil - 6 Years Ago
I have a Y-Block thermostat housing that does not have the bypass hose fitting. Where can I buy this fitting?
By Rono - 6 Years Ago
Well, I've never seen one without the bypass fitting because I think they are pressed into the housing. The hose end is a 5/8" barb that any good hardware store should have, but the housing I don't believe has threads for a bypass fitting. The outside of the housing looks pretty corroded. How is the inside? If it has a lot of pits I would just get another housing. You don't want any coolant leaks! There are a lot of them out there and they are not that expensive.
By 57RancheroJim - 6 Years Ago
At one time most auto parts stores had the bypass tube, it just presses in. I've seen them on Ebay and I think most T bird suppliers and places like Macs have them. https://www.macsautoparts.com/ford_mercury_passenger/water-bypass-tube-steel-5-8-od-x-2-1-2-long-v8-ford-only.html
5/8 coper pipe will work ,best is if you have a oilpump pickup pipe tube, used that, it is correct size and press fit
By darrell - 6 Years Ago
ive used a piece of copper pipe.just put some type of sealer on and press it in.
got ahead of me
Will this help? https://www.hotrodreverend.com/single-post/2018/12/01/1955-Ford-Part-63-Rebuilding-a-Thermostat-Housing
you have to come up with these fixes are you end up chasing all over the place.you can wait for weeks for some small part.all part of dealing with obsolete parts.
By carl - 6 Years Ago
Give me your address and I will send you one Carl
Done. Thank you!!
Sent you a pm Carl
By paul2748 - 6 Years Ago
NAPA also has the nipple
https://www.napaonline.com/en/p/BK_6601580
Carl,
I got the part today. Thank you!!!
