Posts: 7.5K,
Visits: 205.8K
55charliebird (4/17/2019) Damper is off. I found a small V in the edge of the pulley, but no other marks. Now its rebuild time.....HAS anyone heard of DALE MFG., located in Oregon. His website is detailed about his work. He is reasonable and seems thorough. He explains everything. I like what he says and does. He has a long list of dampers he has repaired. Give me your thoughts. I suspect if you take a wire brush, you'll find some stamped numbers and timing marks in the area 108" clockwise from the hub key slot. I’m not familiar with Dale Manufacturing in regards to harmonic damper repair. If you use them, let us know what you think. I’m currently using Damper Dudes in California for damper repair but always interested in other options. http://www.damperdudes.net//index.php
55charliebird
Visits: 39.2K
Visits: 497.8K
The answer is PULL the Damper. It has to be repaired or you will have more trouble in the future. As far as the timing marks, they are on the lip on the closest puley and may be very hard to see. I had the same problem with the ring. I found the marks, though very faint and took a chisel and deepened them enough to see but not enough to mar the pulley. Then I painted the groves white. I send the damper to Damper Doctor. No complaints 55charliebird (4/7/2019)
I have the damper on the right. Cant find the timing marks yet. Probably will find them when I get the damper off and under a microscope. I cant get a real good picture of a damper to show me how much the "ring" has slid back off of the rubber. My guess is the ring should have about 1/2 to 5/8 inch of steel showing....My ring shows no steel and the ring is completely back up against the engine mount. Hard to explain but that leads me to believe the ring has slid back and it stopped when it hit the engine mount. Better pictures would convince me. The real answer would tell me PULL THE DAMPER OR NOT.
55charliebird
Visits: 39.2K
Posts: 7.5K,
Visits: 205.8K
55charliebird (4/4/2019) After procrastinating for 6 weeks on taking off the pulley bolt, I lubed it weekly......well it came out practically by hand. NOW for the damper pulley. Special tool from Casco...is that the only option? Standard 2 jaw pulley remover doesn't seem to work. ALSO what is this thing called a "sleeve". Is it behind the damper? According to shop manual there is a ford tool for that, also. BTW I don't see where the balance ring has slid back (no rubber showing) but it is against the front engine mount. I would love to meet the guys who worked on this engine before me! Any ideas and thoughts are welcomed.Here’s a picture of a couple of Y dampers. Which one is on your engine?
Because of a moved timing mark I just had my damper and additional pulleys off. It was very easy. I removed the radiator, the center bolt. and used a multitask puller from Harbor Freight. While I was there I took off the steady rest. I had the Damper Dr. rebuild the damper and had it back in a total of 4 days since I live in Calif. Putting it on was in the reverse using a longer fine threaded cap screw I already had and using washers until I could use the stock one. Additional pulleys bolted on then torqued it all. To keep the engine from turning over when using the torque wrench, I turned the engine until #1 was coming to TDC and stuffed in some cotton clothes line rope in the spark plug hole. It pulled out ez after backing the engine using the same hex on the crank. Front seal didn't leak before or now.... Good Luck
The seal is recessed into the timing cover. It would hit the bracket first, then the timing cover and it would be making a whole lot of noise so hopefully you check before it has any chance of reaching the seal although it really wouldn't matter all that much by that point.
55charliebird
Visits: 39.2K
Isn't the timing case crank seal the first thing the pulley would encounter on its way backward? The gear is inside the timing case cover so I think the pulley would hit the seal first. I don't have the pulley off yet, I ordered the puller and installer this morning.
55charliebird
Visits: 39.2K
Thanks, I have new damper pulley tools on the way from Casco.
Visits: 285.6K
Sounds to me like you have mismatched parts. Ted is correct. You either have the wrong engine mount or the wrong damper.
