292 y block in cassville, mo
Posted By RayCarter18 6 Years Ago
RayCarter18
Posted 6 Years Ago
Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)Supercharged (564 reputation)
Posts: 174, Visits: 1.7K
In case anyone needed a 292 possible 312 y- block I found an old fire engine f800 the engine is a C1TE block which I guess is a 292 but it had the 4bbl intake on it. The engine is complete and will rotate from the fan by hand. Well it was complete before I took the ram horn and the 4 bbl intake and carbefator and adapter off of it for a steal at $120. Sorry guys. Anyways they told me I could take the whole engine for $300 if I pulled it. I would get it for myself for parts and a spare if I had the room but I don’t. So I am throwing it out there in case someone lives in the area and is beading parts. It is at Payless salvage yard in cassville,mo hoping maybe I can help someone out.
Posted 6 Years Ago
Posts: 1.7K, Visits: 306.2K
"Well it was complete before I took the ram horn and the 4 bbl intake and carbefator and adapter off of it..."
I wonder if you could do me a big favor?
Is it possible to post the CASTING I.D.NOS and CASTING DATE CODE found on the 4V intake?
I would appreciate it immensely.
RayCarter18
Posted 6 Years Ago
The casting code was C1TE -9426-C I think it’s a 6 it could be a 5. And than there is a G below that.
Posted 6 Years Ago
"The casting code was C1TE -9426-C I think it’s a 6 it could be a 5. And than there is a G below that."
THANK YOU! for the get-back ...
C1TE-9425-C ... Wink
EDIT -
Could the G be an F encircled by a C?
Did you notice a DATE CODE (usually three or four characters)?
RayCarter18
Posted 6 Years Ago
RayCarter18
Posted 6 Years Ago
That’s the only picture I have right now. As I am at work.
darrell
Posted 6 Years Ago
Posts: 455, Visits: 22.2K
when you said f800 i had a bad feeling.thats a 332 truck intake.more or less worthless
RayCarter18
Posted 6 Years Ago
Than why does the casting show C1TE I thought that was a 292 that’s the same as my 63 f100. Is there any way to tell what they are by the #. Also what about the rams horn. Are they the same size?
Posted 6 Years Ago
Posts: 6.1K, Visits: 442.5K
Since you have removed the intake, are the ports stacked or side by side?
darrell
Posted 6 Years Ago
i shouldnt have said worthless someone with a lincoln my want it since it takes a holley
