Visits: 285.6K
When I rebuilt my 292 engine last summer, I installed a new oil pump from Precision Oil Pumps. This oil pump was supposed to be blueprinted. My engine has always had a small oil leak. Recently it has gotten a lot worse. I thought for a long time it was the rear seal. I jacked up the car today and the bolts that hold the plate on the bottom of the oil pump were safety wired. Two of them were loose. I tightened all four bolts on the pump and it still leaks about a drop a minute. Should I remove the plate and use sealer or buy a new pump?
