Anyone see this before?
Posted By MattsY 7 Years Ago
MattsY
Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)
Posts: 82, Visits: 3.6K
As I'm readying my block for the machine shop I noticed this tag riveted to the side of the block. Anyone ever see this before and if so, anything hokey I should know about? Thank you for your expertise!
MattsY
I did a little poking and found it might be a 1958 generator engine. I'm assuming not too much is different from a car engine.
1960fordf350
Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)
Posts: 110, Visits: 2.9K
If it's industrial it may have some differences.   What connecting rods do you have?   What markings are on the crank.   Anything on a crank weight that looks like a $ ?   That would make it a forged crank.
http://forums.y-blocksforever.com/uploads/images/2e6780b3-6e07-4836-8bf9-c3da.jpg
Daniel Jessup
Posts: 2.0K, Visits: 131.1K
That industrial tag was on my C2AE 292 block that I am building a 312 with. It was a generator setup also, with some odd motor mounts but handy nonetheless. It also had a weird pcv setup that I had never seen before.
Daniel Jessup
Lancaster, California
MattsY
I don't remember seeing any symbol like that and I'm certain it's not a forged crank. I think it has CE or something stamped into it. I have C2AE rods. I have another post over in technical about the spun bearing. At this point it's pretty moot what the differences may be, but never the less, I'm curious.
LordMrFord
Posts: 687, Visits: 9.3K
I know one 272cid Industrial engine with tag around here.
Hyvinkää, FI
1960fordf350
Any real info can be looked up at John Mummerts site.  HD truck engines used a drop forged crank and 312 rods.   The pistons had a different pin height.  So being moot don't count!!   Being careful and right is.
MattsY
1960fordf350 (3/23/2019)
You sir are correct, being careful and right is of paramount importance! I made a statement without telling the whole story. The crank is an "EC" that is pretty badly damaged. The rods are C2AE and 2 have spun bearings, so I grabbed a 312 block, crank and rods from a friend with a pair of ECZ-G's for $500. I'm gonna turn the crank to the 292 mains, recon the rods, get a new set of slugs and run that setup.
