Anyone see this before?
Home
Keeping The Dream Alive!
This n That
http://forums.y-blocksforever.com/Topic144879.aspx
Print Topic
Close Window
By MattsY
7 Years Ago
As I'm readying my block for the machine shop I noticed this tag riveted to the side of the block. Anyone ever see this before and if so, anything hokey I should know about? Thank you for your expertise!
By MattsY
7 Years Ago
I did a little poking and found it might be a 1958 generator engine. I'm assuming not too much is different from a car engine.
By 1960fordf350
7 Years Ago
If it's industrial it may have some differences. What connecting rods do you have? What markings are on the crank. Anything on a crank weight that looks like a $ ? That would make it a forged crank.
By Daniel Jessup
7 Years Ago
That industrial tag was on my C2AE 292 block that I am building a 312 with. It was a generator setup also, with some odd motor mounts but handy nonetheless. It also had a weird pcv setup that I had never seen before.
By MattsY
7 Years Ago
I don't remember seeing any symbol like that and I'm certain it's not a forged crank. I think it has CE or something stamped into it. I have C2AE rods. I have another post over in technical about the spun bearing. At this point it's pretty moot what the differences may be, but never the less, I'm curious.
By LordMrFord
7 Years Ago
I know one 272cid Industrial engine with tag around here.
By 1960fordf350
7 Years Ago
Any real info can be looked up at John Mummerts site. HD truck engines used a drop forged crank and 312 rods. The pistons had a different pin height. So being moot don't count!! Being careful and right is.
By MattsY
7 Years Ago
1960fordf350 (3/23/2019)
You sir are correct, being careful and right is of paramount importance! I made a statement without telling the whole story. The crank is an "EC" that is pretty badly damaged. The rods are C2AE and 2 have spun bearings, so I grabbed a 312 block, crank and rods from a friend with a pair of ECZ-G's for $500. I'm gonna turn the crank to the 292 mains, recon the rods, get a new set of slugs and run that setup.
