Won't Start after replacing Timing Chain & Gears
Posted By oldcarmark 6 Years Ago
Posted 6 Years Ago
Last Active: 8 days ago
Re-installed my Engine after having it out all Winter to clean, re-seal, and Paint. I replaced the Timing Gears & Chain using the Ford Shop Manual for Reference. Won't Start. Damper at TDC .Both Valves #1 Closed. Distributor pointing at #1. Got Gas & Spark. I seem to recall Vaguely that the Shop Manual Picture is reversed maybe? Facing the Engine Timing Marks on Gears are on the Right (Oil Filter) Side of Block.That's the Shop Manual.Is it Wrong? I did double check the  Gears before I put it back together but now I am wondering if my Memory is correct and the Shop Manual is wrong?
Threaded View
Threaded View
Forum Post Won't Start after replacing Timing Chain & Gears By oldcarmark ( 6 Years Ago )
Forum Post thats right timing marks to the right.where some get mixed up is they... By darrell ( 6 Years Ago )
Forum Post My engine wouldn’t start back in 2003 when it was rebuilt. I had to... By pintoplumber ( 6 Years Ago )
Forum Post Greetings to all: You forgot to mention that there were 12 chain pins... By FORD DEARBORN ( 6 Years Ago )
Forum Post I did triple check that. If the Damper is at TDC and #1 Cylinder... By oldcarmark ( 6 Years Ago )
Forum Post [quote][b]oldcarmark (3/14/2019)[/b][hr] I did triple check that.... By 2721955meteor ( 6 Years Ago )
Forum Post Left and Right for an automobile or an aircraft are always spoken from... By Joe-JDC ( 6 Years Ago )
Forum Post I have been working on this for last 2 Days. Verified Compression... By oldcarmark ( 6 Years Ago )
Forum Post Use a timing light while cranking to make sure it is not too retarded... By charliemccraney ( 6 Years Ago )
Forum Post [quote][b]charliemccraney (3/14/2019)[/b][hr] Use a timing light... By oldcarmark ( 6 Years Ago )
Forum Post I am starting to Wonder if I am .360 Degrees off on my TDC. The valves... By oldcarmark ( 6 Years Ago )
Forum Post That would be 180* out, not 360*. Joe-JDC By Joe-JDC ( 6 Years Ago )
Forum Post I meant at the Crankshaft. Maybe I am one Revolution out for... By oldcarmark ( 6 Years Ago )
Forum Post If I remember correctly the Eckman (sp) book had the timing chain... By kevink1955 ( 6 Years Ago )
Forum Post Thanks. I knew I read it Somewhere. Good thing the Ford Manual is... By oldcarmark ( 6 Years Ago )
Forum Post I seem to remember that when you install cams that are set with the... By Sandbird ( 6 Years Ago )
Forum Post Didn't touch Cam. Just the Gear and Chain. I think I have installed... By oldcarmark ( 6 Years Ago )
Forum Post Mark, it sounds like the cam timing is OK. The manual says to pull... By Hoosier Hurricane ( 6 Years Ago )
Forum Post Thanks John. I have checked the Plug Wires Twice with them off the Car... By oldcarmark ( 6 Years Ago )
Forum Post If it is at TDC on compression with damper at 0, valves closed (there... By charliemccraney ( 6 Years Ago )
Forum Post Mechanically everything You mentioned is Correct. When I tried using... By oldcarmark ( 6 Years Ago )
Forum Post If the spark is erratic, besides checking the obvious connections and... By charliemccraney ( 6 Years Ago )
Forum Post I had a similar problem with one of my cars last year. I chased it... By Florida_Phil ( 6 Years Ago )
Forum Post ++ on coil wire. I did not have enough voltage at the coil, the car... By Robin272 ( 6 Years Ago )
Forum Post Mark, I think Sandbird is right. The #1 should be at overlap, not TDC... By FORD DEARBORN ( 6 Years Ago )
Forum Post Turning the Engine over to TDC with the Valves cracked Open is not... By oldcarmark ( 6 Years Ago )
Forum Post That is true, It would be overlap. I read Sandbird's post which... By FORD DEARBORN ( 6 Years Ago )
Forum Post When the gears are in the correct orientation while installing the... By charliemccraney ( 6 Years Ago )
Forum Post Thanks Charlie.............I'm usually pretty good at adding... By FORD DEARBORN ( 6 Years Ago )
Forum Post FIXED IT!!!! After puzzling over my Problem and reading all the... By oldcarmark ( 6 Years Ago )
Forum Post Fantastic news, cool.Good to know insufficient air gap can cause "no... By FORD DEARBORN ( 6 Years Ago )
Forum Post Hey Guy's. I figured out my Problem and got it running Today. Read my... By oldcarmark ( 6 Years Ago )
Forum Post Ah yes Pertronix give you that little .030 plastic feeler to check..... By Talkwrench ( 6 Years Ago )
Forum Post This is a little procedure I have gone thru dozens of times every time... By Jack Groat ( 6 Years Ago )
Forum Post I checked and rechecked Valves and Damper to make sure it was on... By oldcarmark ( 6 Years Ago )
Forum Post When I was in a dilemma my grandfather always said :wait till tomorrow... By MoonShadow ( 6 Years Ago )
Forum Post Hate to admit it but I am still having Problems with my re-installed... By oldcarmark ( 6 Years Ago )
Forum Post When using the piston stop, did the pointer point at TDC when... By paul2748 ( 6 Years Ago )
Forum Post Yes the Damper is accurate. That's the first thing I thought of to... By oldcarmark ( 6 Years Ago )
Forum Post [quote][b]oldcarmark (4/2/2019)[/b][hr]Yes the Damper is accurate.... By Ted ( 6 Years Ago )
Forum Post Thanks for the Explanation Ted. After having One more look at it this... By oldcarmark ( 6 Years Ago )
Forum Post Final Update. I got my Car out Today for first Drive since last... By oldcarmark ( 6 Years Ago )
