Difference between a Std. 3 spd. steering column and AT column on 1955 Ford ?
Posted By Melly 6 Years Ago
Difference between a Std. 3 spd. steering column and AT column on 1955...
Melly
Question Posted 6 Years Ago
Posts: 201, Visits: 48.3K
I am looking to do a tranny upgrade from a stock 3 spd. to a adaptor for a C4 or AOD.  First which does the best job? The Ford it a weekend warrior.   One off my biggest concerns is would like to keep a factory looking  column shift. But have found little info on what a AT column consist of.  Can a 3 spd column be converted any way or does it have to be replaced with a AT column all together?  If anyone has done this if you have info and maybe photos that would be great.  Would like to keep the 3 spd but have issuse with knee that id causing problems.  Old age!!
Posted 6 Years Ago
Posts: 6.1K, Visits: 442.8K
The most important difference between the two transmissions you are considering is overdrive.  I don't know how they compare for price.  For a daily driver that will see a fair amount of highway use, overdrive would be good.  But for a weekend warrior, maybe not.  If price is similar, I'd get overdrive.
blocky
Posted 6 Years Ago
Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)
Posts: 127, Visits: 2.9K
hi i will give you a bit of useless information from my own experience in doing just that. first up i am in oz but really this may apply to you as well.when i changed from manual trans to auto  column i over looked the position of the indicator arm!suddenly it was facing the wrong way.180 degrees out.this may not or it may apply to you because we had a real mix of columns over here.like i say this may not apply to you???
Posted 6 Years Ago
Posts: 3.6K, Visits: 497.7K
Another item to keep in mind is what the trans you are going to use came out of.  If you are going to use a column shift get a trans out of a column shift car, a floor shift then get a trans out of a floor shift car.  This may not be relevant with an AOD, but floor shift trans' usually has the trans shifter pointing up while the column shift ones have the trans shifter in the down position.  I found this out when I did a C4 conversion in my 56 Bird.  Fortunately, he trans I got had a shifter that had up and down connections.  With a sedan the position of the trans shifter may be different (opposite).
carl
Posted 6 Years Ago
Posts: 1.2K, Visits: 20.6K
Melly (3/8/2019)
If you need a complete AT steering column I can probably dig one up for you  Carl
